Fuses
I have a Toyota 20 62-4fg20, wondering where the fuses are on this lift truck. I'm not sure if I am having firing problems or lack of propane. Hard to start, when it does only runs for 2 mins tops then will not start for a hr or so. Tried giving it a shot of brake cleaner in breather it started, but not for long, how can I test to see if the propane is leaving the regulator. From what I understand only 2psi from regulator to engine.
  • Posted 31 Mar 2017 12:39
  • By Fabcor
  • joined 28 Mar'17 - 3 messages
  • New Brunswick, Canada
I am not familiar with your machine, but it sounds like it does run on the propane for a little bit correct? If that system has a oil pressure or coolant level sensor they may be tied into the fuel lock.
  • Posted 5 Apr 2017 04:39
  • By 39Ratrod
  • joined 4 Apr'17 - 2 messages
  • Wyoming, United States
Komatsu FD25T17
Taylor TXB180S
Komatsu FD25T17
Taylor TXB180S
