SP3420-30
Can someone help me with a 339 code?
  • Posted 2 Mar 2017 09:18
  • By larry_g
  • joined 2 Mar'17 - 7 messages
Thank you, That is exactly what I did. It appeared to be a loose connection.
  • Posted 21 Jul 2017 04:45
  • By larry_g
  • By larry_g
The 3000 series SP is notorious for loose connectors on the distribution board. First thing to do is just unplug/plug back in all the connectors. It may also trip a 342 code (traction pot). Connector CA204 on the distribution board is most likely the culprit.
  • Posted 28 Jun 2017 10:47
  • By Ifixit
Voltage appears to be ok. My last error code was 333.
  • Posted 28 Jun 2017 06:16
  • By larry_g
I will give it a try.
  • Posted 27 Jun 2017 07:03
  • By larry_g
Have you checked the voltage with a meter?
  • Posted 27 Jun 2017 06:49
  • By BREWSKI
By the way, I placed a new battery in the unit 2 weeks ago. Two days ago it was running fine. This morning, forward and revers are very slow, reverse almost non existent. Any ideas?
  • Posted 27 Jun 2017 06:40
  • By larry_g
Thank you, I found it as well.
  • Posted 27 Jun 2017 06:37
  • By larry_g
339 Access 3 module (MRC1) Detected low battery
Steer Trac Lift Disable
Check batt and Connections
If event persists R&R MRC1
  • Posted 9 Mar 2017 04:56
  • By chevotaman
  • joined 28 Feb'14 - 112 messages
It's all just nuts n' bolts.
Sue Tomic Sue Tomic
JCB 533-105
SMV (Konecranes) 4632CC5
Bolzoni SpA (Group HQ)
