RC5500 error code 759 & 760
Hi,
I have a RC5500 with error codes 759 and 760. Someone knows what they mean?
Any help with be greatly appreciated it.
Thanks,
Carol
  • Posted 24 Feb 2017 01:52
  • By UPC8532
  • joined 11 Nov'16 - 8 messages
fixed mine today!! had to replace brake coil raise mast.....easy fix.....i had a spare part
  • Posted 24 Aug 2024 12:34
  • By kingkuality
  • joined 21 May'17 - 61 messages
I had this same problem. Changed the drive motor out and had the same result.
We found the Access 3 module was bad. Our tech put in a good used one and flashed it.
This solved the problem.
  • Posted 6 Feb 2020 01:04
  • By okijohn
  • joined 26 Jul'17 - 1 message
  • Illinois, United States
Any update to what you found?
  • Posted 18 Oct 2019 22:38
  • By AgentK
  • joined 27 Mar'19 - 6 messages
  • Maryland, United States
Customer Service First, fixing comes later
I am having same code issues... I pulled the M2 motor/drive unit assembly off as it was turning really slow if any at all while wheels were raised and steer tires straight. I could turn the drive unit very easily and had no binding or slipping with it after having the motor removed from whole assembly so I figured the trouble was with the motor and replaced it. I'm still getting the 760/759 codes. Any suggestion's??? anyone
  • Posted 15 Jun 2019 09:23
  • By werthy1
  • joined 27 Feb'16 - 26 messages
Do the above and if the tires are turning about the same speed (steer tires in the straight position) check both the encoders in the analyzer ECR1 and ECR2 if the counts looks right then see how much slack you have in the drive unit (truck blocked up)
If everything looks good go to F27 in features and disable it, drive the lift to ensure everything is working right.
  • Posted 6 Apr 2017 10:43
  • Modified 6 Apr 2017 10:45 by poster
  • By Zerk
  • joined 21 Apr'16 - 28 messages
  • Arkansas, United States
Left and Right drives are not syncing up. Block truck up with tires off the ground and see how motors are turning when selecting travel.
  • Posted 26 Feb 2017 11:00
  • By popeye
SMV (Konecranes) 4545CCX5
Taylor T520S
