Will not start. Intemittant
I have a 30L-7 Ser# HFO310229. I has an intermittent start issue. I have changed plugs. Put a diaphragm in the mixer and a kit on the propane side of the EPR. There is no apparent time. It can be cold and it can be warm. I have jumped the onboard diagnostics and no codes. Fuel lock off appears to work all the time. I have jumped the fuel pressure switch. No change. Disappear for a few hours, come back. Starts immediately. There was a lot of contamination in the LPG system for only 1100 hrs. The gasket was deteriorating and a rubbery silicone substance was the product it left in the Regulator. Completely cleaned and rebuilt. HELP!! Anyone else ever seen this??
  • Posted 14 Jan 2017 13:57
  • By chuck_c
  • joined 10 May'15 - 18 messages
  • British Columbia, Canada
I know its been awhile but I was wondering if you ever found a fix for this? I have a similar problem on a 25l-7 with the GM 3.0 with 1500 hrs. I have tried to go through everything, just randomly dies then takes a little while and starts right back up. setting no codes, and with a spark tester it shows even after it dies it has spark the whole time.
  • Posted 6 Apr 2017 09:49
  • By vashxj
  • joined 6 Apr'17 - 4 messages
  • illinois, -
Taylor TT300
USD98,500
Taylor TX330S
USD159,500
Kai von Berg Kai von Berg
Taylor TT300
USD98,500
Taylor TX330S
USD159,500
Lift Technologies Inc.
