E-112 error code
I recently acquired a used Raymond from a client, I know the batteries are bad and I have had it working intermittently. Today after some usage it gave me a E-112 error code and won't move,any help would be appreciated. Also where can I find a code book for this particular Raymond? Thanks again.
  • Posted 30 Nov 2016 09:33
  • By JimDev1
  • joined 30 Nov'16 - 14 messages
  • Oklahoma, United States
James Dever
Ok Ray maybe you can help with this one also,I changed out the switches just fine but now it doesn't move forward or reverse and no error codes.It raises and lowers and the horn functions but no movement any suggestions
  • Posted 3 Dec 2016 00:49
  • By JimDev1
James Dever
ty Ray I checked it and one of the arm switches had a bad lead and was breaking off,will replace switch thanks a million.
  • Posted 2 Dec 2016 05:51
  • By JimDev1
James Dever
Code E112 is a arm angle switch code Go to the bottom of the tiller arm and remove the plastic bumber stop. You should see 2 switches Test
  • Posted 2 Dec 2016 05:14
  • By ray_c
  • joined 20 Feb'07 - 4 messages
  • Minnesota, United States
Terberg RT223
TCM FHD105Z
ROYPOW
Kai von Berg Kai von Berg
