Doesn't move every time
I have a Raymond 111tm that walkie that doesn't move back and forth every time you rotate the handle. Any help on a direction would be great.
I never knew how hard it is ti get info on troubleshooting on these units. All my dealer wants to do is send some one out
  • Posted 25 Oct 2016 02:03
  • By AWOZ1971
  • joined 25 Oct'16 - 4 messages
  • Illinois, United States
Cool thanks.
I was going to just replace that but a while back I turned an old Clark into a new one. I kept throwing new parts at it to fix a problem that wouldn't go away. It got very expensive.
  • Posted 25 Oct 2016 06:11
  • By AWOZ1971
2,1 is battery under voltage
1,2 is throttle pot.
I would start with the throttle pot, it's most likely your problem they wear out frequently. The wiring can also cause this, the harness sometimes gets pinched around the drive motor or stretched where the handle pivots. Chassis shorts can cause this and other problems.
  • Posted 25 Oct 2016 05:37
  • By stam
SER # Is 111-04-55547
  • Posted 25 Oct 2016 04:55
  • By AWOZ1971
It's a 2004 111TM-F60L. The light blinks a code 21.
  • Posted 25 Oct 2016 04:54
  • By AWOZ1971
There is a red light on the console where the hour meter and keyswitch is. This light blinks flash codes. The next time it's not working hold the throttle on and count the blinks.
Depending on year of manufacture it may not be there.
Model and serial number would be handy but I'm going to assume it's a newer unit.
  • Posted 25 Oct 2016 02:30
  • By stam
