Retrieve error code
Trying to get the error code from dash light using pedal dance, must be doing it wrong is it a different sequence?
  • Posted 22 Oct 2016 06:26
  • By pat_r
  • joined 3 Jul'13 - 25 messages
  • British Columbia, Canada
retrieve codes
turn the ignition switch on with accel. pedal released,after 3 seconds fully depress the accel pedal 5 times within 5 seconds(end in released position).
clear codes
After 7 seconds(timing is very important...1 mississippi 2 mississippi etc....) press and hold down accel pedal for approximately 10 seconds(again timing) until the hour meter starts blinking, release pedal and push down and hold again for 10 seconds) hour meter should be on with no codes showing,shut key off and test to see if codes cleared.
  • Posted 23 Oct 2016 07:58
  • By tool_king
  • joined 1 Jun'10 - 21 messages
  • New Jersey, United States
