Fault Code 522735-6
Fault code 522735-6 on a Yale with 2.4 Chevy Vortec S/n A910v
Would like to know if anyone knows, want its referring to.. Thanks
  • Posted 19 Oct 2016 05:07
  • By Stingray69
  • joined 19 Oct'16 - 10 messages
Check the voltage at the sensor plug. Should have a 5 volt supply voltage. If it is battery voltage you will need to check the harness for shorting. I would start by replacing the sensor.
  • Posted 19 Oct 2016 06:34
  • By BREWSKI
Any idea on where I should start, to correct it? I do have another I could use for parts.. Thanks.
  • Posted 19 Oct 2016 06:29
  • By Stingray69
Pre-Cat Bank1 Reading High.
1. Sensor return shorted high.
2. Functional failure in controller.
  • Posted 19 Oct 2016 05:45
  • By BREWSKI
Hyster
Michel Denis Michel Denis
