low power won't climb hill
The engine will free rev OK, and it also accelerates on flat ground and the engine speed comes up with the forward or reverse speed.
On any hill, it won't rev up, and won't climb.
It is a shuttle type automatic transmission, forward and reverse on a column lever.
This is a project with deferred maintenance we just acquired.
It starts and runs smoothly, all functions are good except it needs a service brake overhaul.
My first suspects are a gummed up vaporizer or carb, possibly a timing issue.
The fluids are very clean and no leaks.
  • Posted 26 Sep 2016 14:09
  • By kelly_c
  • joined 26 Sep'16 - 3 messages
  • Washington, United States
Thanks guys, I will look into that next time I run it. Right now it sits in a pretty wet spot. Gotta love the PNW
  • Posted 2 Mar 2017 06:14
  • By kelly_c
I ran into a truck once that was same way,customer thought was trans issue...turned out the Impco CA50/55 carb was hanging up in bore under load and was out of adjustment on the power valve...
  • Posted 22 Feb 2017 08:15
  • By kevin_t
check your fluid level.It has two reserve tanks.Might be going dry on a hill or incline. check the vac advance in distreb.
  • Posted 22 Feb 2017 07:27
  • By Printman
  • joined 22 Feb'17 - 1 message
Help and be helped !
Manitou MH25-4
Taylor T650L
