Adjusting plate
Greetings
I dissembled the right drive unit on a crown RC5530, and removed the adjusting plate, that I thing adjusted the drive axle preload????
It is threaded , turns 360 degrees , and has two locking set screws.
What is the proper way to adjust this plate, it is not covered in the coustomer manual.
Thanz
  • Posted 6 Aug 2016 05:07
  • By harold_c
  • joined 19 May'11 - 11 messages
  • Maryland, United States
Are you talking about the wheel hub with the five studs that the wheel bolts to? This has a castellated nut that secures it with two cap screws. The locking nut is torqued to 542 NM (400ftlb). As long as you haven't removed the wheel hub you should be ok as it needs to be heated to 200 degrees C (400f) before fitment and the nut immediately fitted to the correct torque.
  • Posted 15 Aug 2016 10:26
  • By techno_nz
  • Canterbury, New Zealand
Terberg YT220
Toyota 02-2TD20
Terberg YT220
Toyota 02-2TD20
