Truck won't move
I need a general troubleshooting flow chart for truck drive issues.
steering works
battery lvl 50%
lift actions all work
seat switch sounds to be functioning
two codes show on display at poweroff 0737 and 0307
no other codes
parking brake functions normally
I can send pics if needed
  • Posted 14 Jul 2016 23:26
  • By calvin
  • joined 14 Jul'16 - 19 messages
  • Illinois, United States
if contactor pulls in and drops out then you have a SCR problems. check rec 2 & 5.
  • Posted 12 Apr 2017 15:43
  • By ProL1ft
  • joined 10 Apr'17 - 1 message
One contactor does pull in and the steering pump starts, otherwise, no other contactors energize or de-energize. I assume since the parking brake light goes on and off as appropriate the park switch is fine.
  • Posted 12 Oct 2016 03:32
  • Modified 12 Oct 2016 03:52 by poster
  • By calvin
Are the fwd/rev contactors in the back clicking when you select a direction, release park brake and press the accelerator? If not, check park brake switch behind left hand dash cover and accelerator start switch on accelerator pedal. The two 'codes' are hour meter readings.
  • Posted 15 Jul 2016 19:38
  • By techno_nz
  • Canterbury, New Zealand
Kalmar-Ac P100CXD
SMV (Konecranes) 12-1200B
