Dies at times
Serial # B809N05197C
truck will die when in "tilt bypass" at full throttle, then let off full throttle. Vac. idle up solenoid appears to be operating as it should, if we put it at full throttle, and NOT in "tilt bypass" and let off then machine stays running. Any suggestions?
Thanks in advance!
  • Posted 9 Jun 2016 02:29
  • By JAYS
  • joined 16 Apr'16 - 26 messages
  • Iowa, United States
Sounds like a regulator problem. Is this a emission compliant truck? You might try draining the tar out of the regulator.
  • Posted 9 Jun 2016 03:45
  • By BREWSKI
Briefs United States
MAXAM Tire, Inc.
Unicarriers FD80-2
Terberg YT222
