remove the left axle end assembly
Hello,
I need to remove the both axle end assembly in order to change the brake cylinders
the right side axle come out easily but the left side axle won't come out , I saw here that they seems different , the left side seems to have a pignion wheel :
http://constructionforklifts.tpub.com/TM-10-3930-647-14-P/TM-10-3930-647-14-P0237.htm
is there something that needs to be remove to get the left axle end out ?
  • Posted 26 Apr 2016 21:27
  • Modified 26 Apr 2016 21:27 by poster
  • By Samsam
  • joined 6 Nov'15 - 5 messages
  • Bretagne, France
Good news
I would change all brake parts including adjusters. Don't forget the inside axle shaft seals and o -rings
  • Posted 27 Apr 2016 05:56
  • By Prentice
Hi,
it was one threaded stud too much dirty and rusty, who was disallowing the axle end to go further , I remove it by tighting two nuts together, immediately after that the axle end came without trouble,
next step is to install the wheel cylinders and put everything back in
  • Posted 27 Apr 2016 05:52
  • By Samsam
  • Bretagne, France
Hi , thank your for the answer.
I will open the round shaped cap in the middle of the diff to see what I can see. I was thinking about like you said something wrong like to much wore or may be twisted... I hope it is not too bad in Thérè
  • Posted 27 Apr 2016 02:15
  • By Samsam
  • Bretagne, France
The 1 time i've had that happen it was the upright mounting had wore out the bushing so bad that it ate into the diff. housing and was resting on the final drive studs holding it in place. so check to make sure all of that is good before prying on it to much. after that there should not be much left to hold it there. hope this helps
  • Posted 27 Apr 2016 00:59
  • By Adams1
  • joined 24 Jun'15 - 61 messages
  • Indiana, United States
Make sure the housing is not hitting frame. and brake lines are free and clear. the inner pinion does drop a little bit doing one side at a time is what we normally do. enjoy the day
  • Posted 27 Apr 2016 00:09
  • By Prentice
Hi, thanks for your answer
All 10 bolts or nuts are removed, the axle end come 2 inch out and Thén stay locked Thérè. Évén with lever pulling on it it stays Thérè.
To try to remove it I réinstall the right sidé as I Read on the forum they must be remove one by one or the inner pinions will fall
Sorry for the accent on the "e" , my phone is making that
  • Posted 26 Apr 2016 23:57
  • Modified 27 Apr 2016 00:01 by poster
  • By Samsam
  • Bretagne, France
Make sure all your nuts have been removed from the outer differential. Some are up and under the diff
  • Posted 26 Apr 2016 23:01
  • By Prentice
ROYPOW
edition #1257 - 20 November 2025
SMV (Konecranes) SL37-1200A
Taylor XC300M
New - Sale & Hire
Taylor XC300M
New - Sale & Hire
