New alternator not charging
I have a CAT C3000 lift just put a new battery and alternator on the unit and the alternator is still not charging. Any help pointing in the right direction would be nice.
  • Posted 8 Apr 2016 05:50
  • By sbhbrett
  • joined 18 Mar'16 - 17 messages
Thanks for all the input guys.
I did find the problem, it was a broken wire in the harness, that goes the the regulator portion of the alternator.
  • Posted 14 Apr 2016 03:17
  • By sbhbrett
where are you checking the output voltage at?
if you are checking it at the battery try checking it at the output terminal on the alternator (the large terminal on the rear of the alternator) where they #10 wire is connected to.
If you still do not have voltage output of at least 14.2v then the alternator is defective.
In my experience on these mitsu/cat trucks generally when the battery dies or the truck gets hard to start due to low battery voltage and it is related to the alternator output it is related to the wire and the fuse links (and or the disconnect if it has one).
Check the output at the alternator and again at the battery and see if there is any voltage drop, usually there is, if so check the fuse links inline on that battery wire, there should be 2 of them. The connections are bad about corroding up and interfering with the charging of the battery.
If by chance you have a battery disconnect switch on the unit you should check the resistance across it to see if that is effecting the charging. If there is a battery disconnect switch it should be a black box located on the left side of the truck behind/beside the battery.
good luck
  • Posted 13 Apr 2016 23:11
  • Modified 13 Apr 2016 23:11 by poster
does this truck have an enclosed alternator? (LPS rated) it may be that the LPS electric power physical disconnect box is not making good contact internally.
  • Posted 13 Apr 2016 21:18
Make sure that bulbs in place & not blown. The alt needs to see the draw of that light to " turn on"
  • Posted 13 Apr 2016 01:56
  • By bbforks
The charge light is the one that looks like a battery. Is there 12 volts at the terminal on the alternator? If not I think there is a big fuse that could be blown.
  • Posted 13 Apr 2016 01:54
No, i don't think that this unit has one. if it has a charge light it does not come on.
  • Posted 13 Apr 2016 00:01
  • By sbhbrett
Does the charge light come on?
  • Posted 8 Apr 2016 07:42
  • By bbforks
UN Forklift FBR25NQC3
Crown SX3030TT4250
VETTER Industrie GmbH
Oxford Ct, United States
Crown SX3030TT4250
