I have a Linde h30d, does not crank(starter is good).
Codes t348 t349 t370 show with key on. I suspect bad wiring, could someone help me figure out what these codes mean and a wiring diagram would awesome.
H30d
333735
h2x39u01835
thanks
Showing items 1 - 20 of 20 results.
Hello,
I am having a problem with a H35T S/N H2X39W04080 with the same codes; the engine runs and hydraulic works but no forward or reverse all wires have been inspected and fuses but still no answer. I did see where the speed sensor may have been the issue I am just looking for feedback on if we would all agree this could be the issue. I have reached out to a Linde dealer seeing if I could get a service manual, but they blew me off. If anyone could help that would be amazing.
Thank you
with the manual I was able to narrow it down to the injection pump or speed sensor. the speed sensor checked good, however thew injection pump did not check good.
i sent you whit wytransfar
Still not cranking? I think that is your starting point. Did you receive the wiring of the starting circuit?
Is the key switch ok?
Is the battery ok? Also under load?
Per the linde dealer, The truck has the proper computers. So whats next lol?
does anyone have a service training manual for the linde 393?
I do not know I can not recall the number VW in Lindos
Normal's on the box VW also a linde NR
So the Vw computer is not the right one? I guess that would explain it
Im gonna try and find a vw computer and try that
linde box oke
is on vw box no linde part nummer look like 000 944 01 04???????
Linde computer
R 917 002 888
390 360 14 24
plz add your email in your profile
does not crank? IIRC the starter is wired quite conventional, so check:
keyswitch, start relay, brake switch, fuses, wiring.
but I agree codes are weird.
vw
038 906 012 JG
DIESEL EDC15VM+ 4311
BOSCH
0 281 011 365
whatt is part NR off vw computer?????
was not running when I got it. so anything is possible.
that's certainly strange
replacing the computer?
hep you Linden laptop?
Own Creation how is this problem?
thats weird cause this lift is diesel
verry straens
348 gas shut of valve maximum current exceeded lpg trucks only
349 lpg shut off valve current too high
370 safety processor detects deviating feedback signal at pwm power stages for ic engine actuators
you neet laptop for log on truck
