Line break valve ......
I am in need of the valve that prevents the cylinder from dropping if the cylinder line fails ( not sure of the correct name for the valve ).
I still have the valve ( and it still seems to work ) but it is in rough shape. It looks like a lot of battery acid has spilled on it over the past 30 years.
It has 3/8" female pipe threads on each end and is about 4" long.
I was able to read the numbers 19012DWS-3-9.0 and D-2 off of it.
The lift is a Raymond 20R30TN... Serial Number 020-82-21354
Is this part still available or is there a replacement for it or ????
Thanks so much......
Mike
Jericho, VT
  • Posted 10 Feb 2016 13:55
  • By xtal
  • joined 3 Feb'14 - 43 messages
  • Vermont, United States
Part # 520-124 I think a Raymond dealer should be able to get one. About $200
  • Posted 10 Feb 2016 22:33
Almost forgot.... the new one can have 1/2" fittings on both ends but the same flow. All the tubing and hose is 1/2" (the cylinder has a 3/8" NPT fitting on it).
Thanks again.... Mike
  • Posted 10 Feb 2016 14:21
  • By xtal
