Fault code 31
Hi does anyone know if code 31 is a faulty or maladjusted pot on accelerator?? Truck drives fine then just cuts out? Thanx in advance gary
  • Posted 5 Nov 2015 21:53
  • By G3ryu
  • joined 16 Sep'15 - 14 messages
  • Derbyshire, United Kingdom
G
Thankyou for that had a feeling it was something to do with the pot!!! Or gears as you say thankyou for that least I know I looking in right place!!! Cheers gary
  • Posted 7 Nov 2015 03:15
  • By G3ryu
Hello
If it's 335-02 truck, it probably means, you have the problem with the traction pot or with the small gears linked with it.
All's located under the pedals, on the left side of the truck.
Check the plastic gears for wear, eventually replace. The same with the potentiometer.
  • Posted 7 Nov 2015 00:07
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
I know your deepest secret fear...
J.M.
