hard steer at idle
forklift steers fine when moving--hard steering when sitting at an idle
I had replaced the steering pump with a reman and the power steering motor and pump when the pump gave out. Any advice would be appreciated. Thanks
  • Posted 24 Sep 2015 11:06
  • By goldbrick
  • joined 4 Mar'15 - 13 messages
  • Oklahoma, United States
orbital valve is failing
  • Posted 2 Oct 2015 12:24
  • By fixnproblems
  • joined 19 Jan'13 - 66 messages
stam -- Thanks--good thinking--checked and greased--that's not it--if you can think of anything else---let me know
  • Posted 25 Sep 2015 10:13
  • By goldbrick
Greasing up the steer axle can go a long way.
Check for bad kingpin/bearings.
  • Posted 24 Sep 2015 23:26
  • By stam
Toyota 02-8FD30
Toyota 02-8FD25
Linde Material Handling
