FAULT 29
Hello, need some help, what does code 29 in a Mitsubishi FB18KT means?
thank you
  • Posted 22 Aug 2015 01:48
  • By montse_p
  • joined 22 Aug'15 - 2 messages
  • BARCELONA, Spain
Bad left motor field ciruit.
check the drive motor for shorting. chech the H-bridge card. if this is in a damp enviroment i have seen the 8 diodes on the H-bridge rust away Could be the logic card i have not seen many of these fail. but possible. could be the cables under the battery where they go under the bulkhead i've seen them wear there. make sure you are grounded when trouble shooting as these trucks are are static sensitive and can take out other componets when handling them good luck
  • Posted 22 Aug 2015 02:50
  • By Adams1
  • joined 24 Jun'15 - 61 messages
  • Indiana, United States
F. Uchiyama
