Multiple codes C28-E104-E107-e150-E200
C28- check 10amp fuse or check for stuck lift solenoid
E104- check for broken wire around control handle pivot or check for code 12 flashing on controller indication bad controller
E107-Make sure charge on battery is good before beginning any repair. if battery charge is good check traction fuse ANL-250
E112-Angle arm switch broken or broken wire from switch to controller
E142-check for broken wires at drive motor
E150-If with code 'C28 power amplifier
E157- check for insulation split on CAN-Bus harness
E200- check for broken wire at drive motor
Hope this helps and some of the things I have found over they years the book does not explain clearly
  • Posted 25 Jul 2015 04:13
  • By tomas_s
  • joined 24 Sep'10 - 60 messages
  • Bahamas, Bahamas
More than likely you have a bad battery or corroded battery cables. Possible but less likely you may have a bad "pre-charge resistor" (small whit component with a diode glued to it close to on/off switch).
  • Posted 21 Jul 2017 19:34
  • By darrell_s
  • joined 14 Feb'17 - 2 messages
I have a c28 on my 102xm also... I've literally swapped everything but the lift pump and motor from another machine to try and trouble shoot it. Still have that dang code and its a 2015 model just out of warranty. Any suggestions ?
  • Posted 30 Jun 2016 00:12
  • By DanMc
  • joined 8 Jun'16 - 80 messages
C28 can also be bad on/off switch. Check line contactors welding up too
  • Posted 6 May 2016 07:33
  • By troy_m
Hangcha FLDCXT160
UN Forklift FBR25NQC3
MAXAM Tire, Inc.
Sue Tomic Sue Tomic
