Looking for reach truck to fit 2600cm. pallet face to pallet face
Hi All,
I'm wondering if i could get some help on this topic.
Thank you
  • Posted 4 Feb 2008 12:44
  • By jason_p
  • joined 4 Feb'08 - 3 messages
  • Victoria, Australia
Good friends are hard to find!
am just need cone 80 how i can ge it
  • Posted 6 Apr 2009 12:46
  • By angel_v
  • joined 6 Apr'09 - 21 messages
angel
Check out the range of pallet trucks here - type sitebox pallet trucks into google. They do some really cheap stuff, maybe of help?
  • Posted 9 Mar 2009 23:13
  • Modified 9 Mar 2009 23:14 by poster
  • By dillion_t
  • joined 9 Mar'09 - 1 message
  • 123, United Kingdom
We are a dealer for Aisle-Master which is manufactured by Combilift. It is very similar to the Bendi and should do the job. Although we are not located in Australia, if you contact us, we will be able to get you in touch with the closest dealer. Also, you can see a spec sheet for the Aisle Master on our web site. It's a great product that's very well made.
  • Posted 21 Feb 2008 11:01
  • By eddie
  • joined 21 Feb'08 - 6 messages
www.combiliftdepottx.com
We do the Bendi forklifts which work as small as 1.6 meters pallet face to pallet face. And as High as 12.5 meters. 3 wheel & 4 wheel. Work inside and outside in semi rough terrain unloading trucks and containers to stack palletised goods inside into very narrow aisles. We are the Australasian agents for the 'Bendi' machines made by Translift in the U.K and Landoll in the U.S.A
  • Posted 21 Feb 2008 09:00
  • Modified 21 Feb 2008 09:01 by poster
  • By stringfish
  • joined 21 Feb'08 - 3 messages
  • Auckland, New Zealand
Anything else is a waiste of space!
Dear Mr UWE B:
You are so professional that you are familar with
UK's markting.
Learn from you.
  • Posted 17 Feb 2008 20:42
  • By Moon
  • joined 8 Jan'08 - 45 messages
  • NingBo, China
In Europe and now in the states Bendi's and CombiLifts version are becoming very common place. They will work in a 6ft (183.00 CM) aisle. Check their website at "Landoll" under material handling.
Or look at Combilift, they are both great products.
They show the application data also.
Good luck,
  • Posted 17 Feb 2008 10:18
  • Modified 17 Feb 2008 10:21 by poster
  • By uwe_b
  • joined 29 Mar'07 - 3 messages
"Seek not to be a success but rather to be of service."
Albert Einstein
Hi, Jason_P.
I am Moon, from China.
We have the suitable products, if you need, pls let me know.
My connection is onlymoon(at)live.cn.
I am waiting for your news.
Moon
  • Posted 15 Feb 2008 18:39
  • By Moon
  • NingBo, China
I have a couple of questions:
Do/will you have bottom beams ( Ie first pallets off the ground)
what goods are you handling ( ie heavy/light, are they well packed or neat pallets.
As the above mentions, Crown/Raymond do a good pantograph truck which I have seen in a 2900mm aisle, and thats no mucking around room for error sort of stuff. Bottom beams will ad a cost to your rack but will allow for straddle legs (depending on the model you choose) to go under the rack, which will enable an easier (yet Illegal) drive with the load straight into the rack. To be comfortable and without compromising productivity an ailse of at least 3200mm would be nice. Toyotas reach truck as with most sit down reach trucks wont work in an aisle like this though.
  • Posted 15 Feb 2008 16:25
  • By DA_GUN
  • joined 17 Jan'06 - 5 messages
  • New South Wales, Australia
I make a very good living doing this sort of thing but can not quite understand the question. 2600cm =1023 inches or 85.25 ft. and that is one **** of a reach. Normally reach trucks work in a 9 ft aisle depending on the load. Toyota, Raymond and many others make a good unit for this.
Uwe
  • Posted 15 Feb 2008 01:06
  • By uwe_b
MAXAM Tire, Inc.
MAXAM Tire, Inc.
Mitsubishi FGE35AT
Toyota 8FD45
