Hoist functions shut-down. must shut off & turn back on at key switch
codes al313,313,108,111. code al313 or 313 do not show up in service manuel. 313 shuts hyd. functions down and must restart. codes 108 & 111 the units continues to operate. Can someone help or have seen this issue before.
  • Posted 15 Jul 2015 02:08
  • By jerry_c
  • joined 5 Oct'10 - 26 messages
I know this is almost a decade later but if either kf you are still active and have trouble shooting information for fault 313 I would much appreciate it.
  • Posted 29 Nov 2023 04:02
  • By Ryan_Morlan
  • joined 29 Nov'23 - 1 message
appreciate your response. jc
  • Posted 25 Jul 2015 05:24
  • By jerry_c
yeah i've got that HPK document on code 313 alarm code, i could of given that to you and you wouldn't have had to twist my arm any lol :oD
  • Posted 19 Jul 2015 05:44
Thank you for the response we just received a service bulletin from our local dealer after a little arm twisting. It gives us a testing procedure to go through on the unit. If you do not have the bulletin I would be happy to email it to you. jc
  • Posted 18 Jul 2015 02:36
  • By jerry_c
ok that's the sauer danfoss system
let me do some checking and i'll get back to you on this
  • Posted 17 Jul 2015 14:11
DASH DISPLAY GREEN OVAL ONE. S/N 2NR2739715
  • Posted 17 Jul 2015 06:28
  • By jerry_c
What is serial number of truck?
Which display does it have?
There are 2 displays this truck could have
- the small oval green colored one (no function buttons)
- the standard square LED screen (5 buttons along the bottom)
  • Posted 15 Jul 2015 23:59
  • Modified 16 Jul 2015 00:01 by poster
