keep getting Fault code 522132-1
Has anyone run to this problem? Hyster Forklift Model H155FT.
you drive forklift and code 522132-1 pops up and disables the forklift. also does it at times when just parked and running engine then 522132-1 fault code appears and disables forklift? does anyone know what is causing this?
  • Posted 17 Jun 2015 07:12
  • By hector_c
  • joined 17 Jun'15 - 11 messages
  • New Mexico, United States
thank Brewski I ll check that out.
  • Posted 19 Jun 2015 06:40
  • By hector_c
The Code is transmission range 1 lower than commanded. Possible problems. Low oil level, Supply pressure low, Proportional valve failure, sensor failure, controller failure.
  • Posted 18 Jun 2015 07:18
  • By BREWSKI
UN Forklift FD40T
Komatsu FD25T17
