load wheels rubbing
The right side load wheel is rubbing and binding up in the load wheel pocket when the truck is lifted only a few inches. if it all the way down or all the way up it will not rub. I didn't see any adjustment.... Is there and adjustment I don't see. I am sure the truck is bent...
  • Posted 19 May 2015 00:10
  • By shorn
  • joined 1 Dec'11 - 12 messages
I would say that you need to check the load wheel bracket pivot pin locating housing housing for wear and the load wheel bracket for being bent also wear of the load wheel bearing
Regards Nero
  • Posted 19 May 2015 02:17
  • By NER045
Michel Denis Michel Denis
