Clark tmx20 ac code list
Am looking for a code falt list have 2 codes now #19 -
& 79
  • Posted 1 May 2015 04:52
  • By fixer
  • joined 25 Feb'14 - 4 messages
jim biancucci
code 19
Fault Name: Logic failure #1
Fault description: An over voltage or under voltage condition has been detected.
Control: Master
Troubleshooting:
- This fault signals that the under voltage/over voltage protection interrupt has been triggered.
- A real under voltage/over voltage key input (C3) happened. Voltage has been below 16V
- A real over voltage on the power capacitors happened, voltage has been 63V.
- Fault in the hardware section of the logic board that manages the over voltage protection.
- Possible plugging in or unplugging of battery or charger with the key switch on.
Action required:
Replace controller
Code: 79
Fault Name: Incorrect start (SRO)
Fault Description: Warning: wrong traction request sequence. This fault indicates an incorrect starting sequence.
Control: Master
Troubleshooting:
- If SRO function is active, every time work is stopped the operator must put the truck in neutral.
- If forward, reverse or seat switch is active when key switch is turned on.
- If forward, reverse closed without seat switch input.
- if the fault persists after checking the wiring.
Action Required:
replace controller
  • Posted 1 May 2015 22:06
Noblelift
Elwell-Parker ESI500-36
UN Forklift FGL25T
Sue Tomic Sue Tomic
UN Forklift FGL25T
