low pressure on brake
Forklift worked fine. There was just liking on wheel motor.I replaced shaft seal. Reassembled all together. Tried to drive forklift but it wont moved. No error on display. Than I removed hoseline from brake valve. There was not enough pressure on brakes! How can that be?? All of the sudden....??
  • Posted 18 Feb 2015 08:47
  • By borut_veliki
  • joined 14 Dec'13 - 56 messages
  • novo mesto, Slovenia
Also to , need to put grease on the brass plate to hold it in place when putting it back together. plate will shift and unit will have nothing working,
  • Posted 11 May 2015 12:52
  • By edward_m
  • joined 11 May'15 - 111 messages
There is low pressure on brake valve......so between brake valve and gear pump.....
  • Posted 20 Feb 2015 02:02
  • By borut_veliki
When you reassembled it did you line up the holes in the brake discs?
You need to replace ALL of the O rings and seals and inspect everything for wear.
  • Posted 19 Feb 2015 11:02
  • By duodeluxe
  • United States
duodeluxe
edition #1237 - 3 July 2025
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
TCM FD115-3
Hangcha CBD15
China
USD1,600
