code CO16, E011
Need help with these codes, unit has lift but no travel, anybody have any info on these codes, much appreciated , thanks
  • Posted 29 Jan 2015 09:36
  • By All Lift Tech
  • joined 3 Oct'10 - 57 messages
Thanks for the fast reply swoop 223, ill go ahead check it out. I appreciate your help.
  • Posted 29 Jan 2015 13:38
  • By All Lift Tech
C016 is the component number
E011 is the error number
this error according to cats updated error code list:
Offset error of armature/field current (DC) and stator current (AC); current measuring point.
Display text: controller
Cause/Action:
check main power supply cable; replace component.
Now from what i have experienced sometimes the ribbon cables inside the controller will shake or vibrate loose out of their sockets.
You can remove the controller and VERY CAREFULLY remove the cover and check the connecting ribbon cables and see if any are loose. If you do find any loose ones, remove it, clean the connectors with contact cleaner and let dry. Reinstall the cable into the plug and use silicone sealer or some type of silicone around the plug to help hold it in place.
I would also double check the main drive buss fuses and make sure none are broken, do not go by looking at them, use a VOM meter and physically check them. Make sure the main harness connector is fully locked in place too.
  • Posted 29 Jan 2015 13:17
  • Modified 29 Jan 2015 13:19 by poster
