OIL FROM DRIVE WHEEL
WHAT IS THE BEST WAY OFF TAKING OFF THE DRIVE WHEEL UNIT.ITS LEAKING OIL OUT OF SEAL.
I SEE THE RING OF BOLTS AROUND IT. IS THAT IT TO TAKE OFF DRIVE UNIT?
  • Posted 19 Dec 2014 06:39
  • By greasespoon
  • joined 30 Jul'09 - 154 messages
  • somerset, United Kingdom
Also, when you order the seal kit, it comes with two kits, save one for the next drive axle seal
  • Posted 11 May 2015 12:49
  • By edward_m
  • joined 11 May'15 - 111 messages
  • Posted 11 May 2015 12:48
  • By edward_m
Disconnect the hydralic lines going to the drive. Their on the inside, their is a banjo fitting and also take out the pipe spacer.When you pull it out, then you need the linde tools to disasemble it.You will need a multiplyer to loosen the spring tension
  • Posted 11 May 2015 12:46
  • By edward_m
Toyota 02-8FD30
Ncn 110TH
Ncn 110TH 2015
Yale Lift Truck Technologies
