need help with neglected Yale 4000lb
YALE# GLC040ADJUAE083
Runs great... but has been *severely* neglected.
I need help to find:
Most important: Where to find/buy the parts manual/Service manual?
also
Oil filter # and where to buy?
Transmission Fluid type?
Hydraulic Fluid Type?
Dumps red/ATF fluid all over if you fill it, most common failure point?
leaks hydraulic badly if you fill it, again.. most common failure point?
Sorry, I'm new, thanks so much
Ben
  • Posted 4 Dec 2014 08:38
  • By nexus7
  • joined 4 Dec'14 - 3 messages
Serial:N460166
Atf leak turned out to be: filter had holes in it!
Can anyone tell me what year this forklift is?
  • Posted 7 Dec 2014 07:45
  • By nexus7
If your fluids are foamy, you are aerating. Hydraulic filter might be plugged. Check all the tank suction hoses for loose clamps. The Trans is another story. Drain the fluid and start with fresh wen you change the filter.
  • Posted 6 Dec 2014 00:33
  • By BREWSKI
This truck was built before the Hyster/ Yale merger. Transmission should use Dexron fluid. Engine oil filter #150017600, I can not remember the trans filter number but you should not have any problem crossing it locally.
  • Posted 6 Dec 2014 00:29
  • By BREWSKI
Serial:N460166
TYPE: LP GAS
TIRES: SOLID
I can't see anything on the oil filter yet. possibly after I remove it it will become visible. I'd rather have the new filter before that tho?
Does anyone know which HYSTER this Yale cross-references to? (or if it does?)
  • Posted 4 Dec 2014 09:51
  • By nexus7
Have the serial number of the truck?
Do you have a number off of the oil filter that is on it? NAPA has a good cross refrence site where you can cross the number to a NAPA filter number.......as for the manuals could check ebay for a good used one,only other possiblility would be thru a YALE dealer......for fluid types someone would need a serial number first.....
  • Posted 4 Dec 2014 09:47
  • By kevin_t
Muncie, IN, United States
SMV (Konecranes) 4632CC5
UN Forklift FGL35T
Deborah Baker Deborah Baker
