ERASE ERRORS
How can I erase Error E-26 and E-32?
  • Posted 18 Nov 2014 06:49
  • By Tony_RD
  • joined 14 Feb'14 - 3 messages
Tony RD
and Kevin, -ANY- pedal (not just accel pedal, including the brake light error) can not be reset by the pedal dance.
  • Posted 18 Nov 2014 22:17
well E26 is an oxygen heater sensor fault, until you replace the O2 sensor this will not clear.
After replacing this component you will need to run a Fast TAS learn using the laptop program or a GSE handset. This will recalibrate the air/fuel mixture ratio's in the ECM memory.
as for the E32 this is a step 1 overheat code for the cooling system which should clear during the reset but will return if the condition is still present after running the truck for a bit. If it still codes out and you know for a fact the engine is not running hot then look at the temp sensor and its associated wiring for problems.
  • Posted 18 Nov 2014 21:48
Codes wont clear if fault is still present..............just a FYI or if code is for accel. Pedal sensor....will needmtomfix and clear,codes by laptop or unhooking battery for a few minutes to half hour...
  • Posted 18 Nov 2014 07:00
  • By kevin_t
PEDAL DANCE:
clearing codes for K21 - K25 engines
1) turn key switch on, after 3 seconds fully depress acc. pedal 5 times w/in 5 seconds.
2) after 7 seconds, press and hold down acc. pedal for about 10 seconds, until hour meter starts blinking.
3) release pedal and push down again, hold for another 10 seconds
4) hour meter should be on w/ no codes
5) shut off key, and turn back on w/ no codes.
  • Posted 18 Nov 2014 06:58
  • By kevin_t
Esie Cortez Esie Cortez
