Bil-Jax
Does anyone know anything about a ESP 19 Bil-Jax?
  • Posted 14 Nov 2014 04:29
  • By Juice
  • joined 4 Oct'14 - 4 messages
  • Kansas, United States
I recently purchased an older model Esp19. Everything operates on it perfectly. However when the machine is turned on the pump motor stays on and continues to run. It is running at full speed and operates correctly. At first I thought it was something in the joystick that didn't allow it to shut itself off after performing its task. The machine continues to run constantly in upper and lower control modes so if doesn't appear that its something in the joystick module. All of the turning and movement functions perform correctly. Any input would be appreciated. A friend said there is a relay that controls the running of the electric motor that may be stuck. He also thought it may be an issue with the control board. Any help would be greatly appreciated. Thanks. Brent
  • Posted 9 Sep 2020 09:32
  • By Brent_Grismere
  • joined 9 Sep'20 - 1 message
Sounds like the control handle potentiometer needs calibrated....go to the website,download the service and maintenance manual am sure the info is in there.......
  • Posted 14 Nov 2014 06:25
  • By kevin_t
I replaced the upper control handle. Now lift has a intermittent pause when you use the upper or lower control boxes.
  • Posted 14 Nov 2014 06:23
  • By Juice
What is it you need to know???? A very vague question.......can go to biljax website and download the manuals for it if you need them
www dot biljax dot com/main/manuals/
Remove the dot and replace with.
  • Posted 14 Nov 2014 04:55
  • By kevin_t
Sue Tomic Sue Tomic
Komatsu FD25T17
UN Forklift FBRS15KQZ2
Sue Tomic Sue Tomic
