Codes 202 204 213 R
...So I have an ERP 040THN36TE078 that will not move. It comes up with codes 202, 204 and 213R....Can anyone tell me what these mean?
Thanks
  • Posted 24 Oct 2014 08:19
  • By ctforkliftguy
  • joined 14 Mar'13 - 48 messages
  • Connecticut, United States
Hello, you solved this? I have a ERP040TH Yale forklift and the error code is 213R, there is no traction and Line Contactor never. I still can't find the problem after a month. Based on the forklift's manual, this code doesn't even exist.
Help...
  • Posted 3 Jan 2024 11:49
  • By CamachoJC
  • joined 3 Jan'24 - 1 message
  • Mexico
Only cheap stuff is bought with money-
...NER045.....Thank you kindly for the info, could possibly be 212R...per your previous post.....202 also means battery hood switch? I will be checking this truck out this week sometime hopefully....Thanks
  • Posted 26 Oct 2014 23:47
  • By ctforkliftguy
Hi Ct forklift Guy,
Having looked into those codes, 202 means your hydraulic oil is low,
202 means that you may have a problem with the battery hood switch,
You may have to check out the last code you quoted, 213 should come up by itself and not with an R or L which would denote left or right, are you sure it was not 212R or L.
Regards Nero.
  • Posted 26 Oct 2014 23:28
  • By NER045
Hi Ct forklift Guy,
Regards Nero.
  • Posted 26 Oct 2014 23:27
  • By NER045
I think it would be helpfull to have a ser, no. I will look and. See what Ica find on those codes.
Regards Nero
  • Posted 26 Oct 2014 22:07
  • By NER045
Oxford Ct, United States
