transmission
i have a KUGH02A30PV that when put in drive the trans shifts but will not pull unless you rev engine the shifts hard into gear and drives fine until you change to nuetral/reverse or press brake and or the inching cable any help will be appreciated thank you
  • Posted 2 Oct 2014 01:30
  • By rosscoe
  • joined 6 Aug'14 - 8 messages
  • Oklahoma, United States
Sounds like you have possible low fwd drum pressure or you have no friction material left on the drive plates. I would compare fwd and rev pressure and main pressure. Does the unit shutter before engaging harsh?
  • Posted 8 Oct 2014 12:05
  • By RCAV8TOR
  • Alabama, United States
Does the temp of the trans play any role at all with this delayed engagement?
  • Posted 2 Oct 2014 09:26
  • By bbforks
the fluid is a lil dark but not too bad linkage is all good we do have a little bit of slop where it goes down into the top of tranny but it is shifting into drive becuase it pulls engine down just wont pull until you rev and i guess it fully engages
  • Posted 2 Oct 2014 03:51
  • By rosscoe
First i would check the fluid and make sure it is full and not burned. If it is very dark and/or smells burned change it and the filter. Also while drained pull the sump filter located at the base where the main return hose mounts and clean it out.
check the inching cable adjustment too and make sure there is no tension pulling the inching rod linkage or make sure it is fully releasing when pedal is released.
  • Posted 2 Oct 2014 02:36
Hyster
Hyster
