Code 26
Need some info code #26 unit will not move or lift horn is the only thing that will work.
  • Posted 27 Nov 2007 07:45
  • By Smokey
  • joined 20 Nov'07 - 11 messages
Before changing big dollar items make sure fu8 is good. It feeds battery positive power to the power card.
  • Posted 20 Oct 2018 03:52
  • By tyler_d
  • joined 23 Sep'16 - 79 messages
Strangely I just had a OP30 that would code 2D then go right into 26 , changed out TM's , power card,leads after testing for shorts, etc. Thought I had it, came back, swapped motor from another OP that had been running a long time, still coded after a few days. Then I noticed that the truck was slow to start and Q1 didn't sound right even though it and Rect 1 tested good. I changed out Q1, & Rect 1 truck ran normal --for a few days. Code 26 came back, new motor and new power card finally solved it. I believe what happened was this, Q1 was not conducting pulses correctly at lower end causing the power card to pulse the field stronger to start the truck moving due to armature not responding that got the power card(maybe motor). The old motor I swapped from another OP shorted the fields when hot , took out the power card. I was chasing my tail, new motor and another power card solved it but sad case of "known good motor that wasn't" sure put a monkey wrench in the works!
  • Posted 15 Jan 2010 11:02
  • By MtnMan
  • joined 9 Jun'07 - 8 messages
  • Alabama, United States
We work on anything and sometimes we fix something!
the Q1 is in the armature circuit. a 26 would lead you to the power card, open field wires or TM1 or TM2 transistors.
  • Posted 9 Jan 2009 00:37
  • By E_lift
  • joined 9 Dec'08 - 15 messages
JonG thanks thats what ist was thanks for your help. have you had any experience with a CAT EP20T code 50 steering sensor I have replaced and speed sensor and main board.
  • Posted 7 Dec 2007 10:01
  • Modified 7 Dec 2007 10:05 by poster
  • By Smokey
It's probably the drive motor or the cables to the motor. Code 26 is an open detected in the field circuit. It could lead to the Q1 circuit...
  • Posted 27 Nov 2007 08:22
  • By JonG
  • joined 7 Nov'07 - 155 messages
  • United States
Advance CS7000
Illinois, United States
USD8,000
JCB 533-105
edition #1243 - 14 August 2025
In this week’s Forkliftaction News , we look at more financial reports with one major producer recording a “significant” decline in Q2 bookings to report an operating loss of USD8.5 million, while another had a strong quarter “despite increased trade tensions and a challenging geopolitical landscape”... Continue reading
Dwight Klappich Dwight Klappich
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Executive director, NT WorkSafe
Chief executive, Logistics UK
The black box flight recorder was invented by Australian scientist David Warren in the mid-1950s. While initially met with indifference in Australia, his invention gained international recognition, particularly in the UK, and is now a mandatory piece of safety equipment on all commercial aircraft.
Advance CS7000
USD8,000
JCB 533-105
