H25CT 392 series code L236
replaced the potentiometer for the tilt angle but still get the code. checked signal voltage had 4.3v and reference voltage is 2.8v.
should these be the same, that what the code is that the reference signal does not match the tilt angle signal.
  • Posted 31 Aug 2014 00:39
  • By joep56
  • joined 13 Jun'14 - 8 messages
when you replace the sensor you have to relearn the sensor to the system.
a laptop with pathfinder software is required to do this.
  • Posted 1 Sep 2014 01:09
