Splitting tranny from engine?
Trying to split the engine from the tranny in a early 90s FG25T-11. All the bolts seem out, I unbolted the converter from the flexplate, and the engine seems glued to the tranny. Checked carefully for missed bolts, and I do see what appears to be two locating pins. Are there any strange fasteners to look for? I squirted penetrating oil on the seam yesterday, so hopefully some movement tonight.
  • Posted 26 Aug 2014 05:42
  • By josh_k
  • joined 26 Aug'14 - 14 messages
Ok, got the engine out.is there a trick to removing the torque converter? Other machines I've worked on the tc just pops out, but not this one.
  • Posted 26 Aug 2014 12:41
  • By josh_k
Thanks - I'll try again tonight, but I'm sure I found all the bolts.
  • Posted 26 Aug 2014 07:26
  • By josh_k
Very basic trans/engine combo- There are bolts about every 4-6" around the entire bell housing so make sure they're all out. Usually the bottom of the engine/bell housing will start to separate on it's own as the bolts are removed.
There are 2 locating dowels -one on each side- but I've never had an issue with them.
Make sure to support under the trans's bell housing as it will pivot downward with the engine removed.
  • Posted 26 Aug 2014 06:07
  • By bbforks
JCB 533-105
Terberg YT222
