6200 l.p. robin suburu motor cranks but weak or no fire
The tennant sweeper has weak or no spark replaced coil test circuit with service manual but no help be live it is one of the two modules but they are priced high to just test out
  • Posted 27 Jul 2014 08:57
  • By liftv5
  • joined 5 Oct'13 - 33 messages
Yes electronic ignition the l.p. version I'm on has two modules and a low oil sensor
  • Posted 5 Aug 2014 22:01
  • By liftv5
Does the engine have ign points or an electronic pick up assy located under the flywheel assy by the crank? I'm not familiar w/ your exact engine.
  • Posted 3 Aug 2014 10:10
  • By bbforks
As in suburu robin motor there is special nikki l.p. regulator and the l.p. set up is different than gas models it appears to have two ignition control module for spark
  • Posted 3 Aug 2014 02:52
  • By liftv5
robin engine. like reliant robin??? I just saw one at a car show on the weekend always makes me think of Mr. bean lol
  • Posted 31 Jul 2014 19:51
  • By stam
single cylinder?
gee
never seen one of those in a tennant before
Must be made alot like most single cylinder motors like the briggs and Tecumseh engines?
Could be a problem in the reluctor pickup (if it has one of those)
Most of these type engines do have some type of generator component to generate the spark timing on the flywheel to tell it when to spark.
I'm not too familar with these robin engines though.
Can you get any information on this engine from tennant?
I'll see what i can find if you can get the engine number off the engine.
  • Posted 31 Jul 2014 02:04
Replaced spark plug and coil engine is a single cylinder robin motor
  • Posted 30 Jul 2014 07:47
  • By liftv5
have you tried replacing the spark plugs, wires, dist cap, rotor yet?
  • Posted 28 Jul 2014 00:29
Hawker Powersource, Inc.
Mitsubishi FGE35AT
UN Forklift FBRP15NQZ2
Sue Tomic Sue Tomic
