Code 100-3 temp
Can anyone help with this code? Engine is not running hot and all fluid levels are good.
  • Posted 22 Jul 2014 04:05
  • By gene_l
  • joined 19 Jun'12 - 16 messages
if you have the F2 mazda, the sensor is next to oil filter, easy to replace. If you have the GM then thats a bit more tough that sits horizontal agianst the block on top of filter housing but its easier to remove air filter housing, ecu and injector module to replace oil psi sender. make sure connector is good also cause that will cause the fault also, good luck
  • Posted 1 Aug 2014 15:57
  • By YaleTechnician
  • joined 11 Dec'13 - 18 messages
The oil filter on these trucks is awkward to access and if you do manage to get it loose you tend to pull it up past the air filter and gas and vacuum tubes to the regulator pulling against the oil sender wiring connector which then cracks the body of the sensor unit and then you end up with this code.
Nero
  • Posted 23 Jul 2014 00:23
  • By NER045
my book says this is the engine oil pressure (sender) out of range. have you considered changing the oil, oil filter and oil pressure sender?
  • Posted 22 Jul 2014 08:36
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
UN Forklift FGL35T
Brussels Airport in Belgium, Europe is the world's largest sales point for chocolate, with over 800 tonnes of chocolate sold annually. This averages out to about 1.5 kilograms sold every minute.
Libiao Robotics
Libiao Robotics
