misfire after decel from WOT
Hello All,
I'm having a strange symptom with my GLC040AFNUAE082. Serial # is: A809N05268U. After decelerating from WOT, whether under load or not, the engine misfires slightly. It just gets kind of lopey at idle for about 20 seconds, and then smooths out. Ignition components are less than a year old, so I don't think it's a spark problem. I did notice that the "guts" of the PCV valve are gone, so it's essentially an uncontrolled vacuum leak as opposed to a controlled one. Could this cause a lean misfire on deceleration?
  • Posted 10 Jul 2014 01:33
  • By autotech500
  • joined 26 Jun'14 - 6 messages
Administrators- please remove this second post- TY
  • Posted 10 Jul 2014 01:41
  • Modified 10 Jul 2014 01:41 by poster
  • By bbforks
YES! An open vacuum leak can cause all kinds of problems. Before you do anything- replace the PCV valve & retest.
Before I got to the ending w/ the pcv issue my thoughts were the fuel system was malfunctioning. If it's still acting up after the pcv replacement I'd check the fuel system
  • Posted 10 Jul 2014 01:40
  • By bbforks
Nagano NUZ090D
Taylor TX330S
USD159,500
