FORKLIFT BATTERY RTEPAIRS
I would appreciate the inputs from an expert on forklift battery repairs. We come across quite a large number of forklift batteries with one or two bad cells amongst so many good cells. In most cases it would be economical to replace only the bad cells with new cells and bring the battery back to a working condition. We haven't got the experience in replacing the cells, especially the ones with welded cells. Would appreciate if someone could let me know the equipment and accessories required in case we are to start replacing bad cells and repair forklift batteries. Also, please recommend a good brand and a model of a Forklift Battery Impedance Tester for purchase ideally an American or European make.
E mail : dhammika(undersore)umpl(at)stmail(dot)lk
  • Posted 12 Jun 2014 18:33
  • By Dhammi1
  • joined 28 Jul'11 - 68 messages
  • Sri Lanka
thanks a lot to Nero, lifter01 and forkingabout for valuable inputs. We still get reconditioned forklifts with welded cells from Japan (GS and GS Yuasa) and knowing the correct procedure is a must. I will have to find a competent guy (probably a guy with hands on experience) to do the job. Why I wanted to invest in a impedance tester is to analyze all cells of a battery at once, especially at a customer's site. With the impedance tester, identifying the bad cells would be much more accurate.Could you anyway recommend a good multimeter and a hydrometer model for this purpose ?
  • Posted 14 Jun 2014 16:21
  • By Dhammi1
  • Sri Lanka
Portable oxyacetylene bottles can also be used for the attaching the cell straps BUT you have to know what your doing to avoid blowing the battery up in your face.
In the past days of older traction battery design one of my battery repair guys used oxyacetylene the other used the resistive soldering iron kit.
It was pretty funny watching everyone disappear to the other side of the building when the hot blue spanner was in use as the battery repair guy did his stuff & I stood there with the fire extinguisher.
Most traction batteries are bolt on cell straps these days, far easier to deal with & repair.
  • Posted 14 Jun 2014 05:17
  • By Forkingabout
  • england, United Kingdom
You don't need an impedance tester a decent multimeter and a hydrometer does the job fine. Check the voltages off load and under load and check the SG its worked fine for me for years
  • Posted 14 Jun 2014 04:52
  • By lifter01
  • joined 4 Jul'09 - 461 messages
You could do with a post drill and a salters ripper tool to push down the sides of the cells to loosen them of in the pack to enable you to pull them clear of the pack.
Nero
  • Posted 13 Jun 2014 18:14
  • By NER045
Thanks Jeremy_s for your valuable inputs ! I do not mind investing in a impedance tester though they are expensive and I know all best impedance testers are made in the U S A. Could you recommend a brand and a model ?
  • Posted 13 Jun 2014 12:36
  • By Dhammi1
  • Sri Lanka
I would look into a load bank tester to check for bad cells using a volt meter and hydrometer. Get a welding ground clamp, a 3 foot length of no 2 cable, and an electrode holder, then use carbon rod and a few battery cells for a power source. Get some lead bars, and the proper hole saw and you should be set to repair batteries.
  • Posted 13 Jun 2014 08:05
  • By jeremy_s
  • joined 28 Mar'08 - 205 messages
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
VETTER Industrie GmbH
Hangcha CPYD70XW24B-C
Flesherton, Ontario, Canada
Terberg RT223
