error code e o1 5
I installed new o2 sensor on 8fgu25 and tried to clear code with pedal sequence. Code will not clear. I have 12 volts on red/blue wire and 0.1 volts on green/red wire. Is this correct? Code doesnt even attempt to clear. Bad ecm? Am I missing something else that I can check or is there another method of clearing codes? None the less, the truck still I idles rough and is lacking power.
  • Posted 30 May 2014 04:25
  • Modified 30 May 2014 05:23 by poster
  • By schoop
  • joined 18 Oct'13 - 4 messages
  • Michigan, United States
You also need to read the information going to the ecu. o2, vf voltage, and injection period.
  • Posted 3 Jun 2014 07:54
  • By rogeriwt
