linde h25d drive fault
no drive in forward and reverse after first start up.sometime i can feel it trying to move but not.and does not rev at first as well.
found brake valve block leaking replaced still the same.
but if you push down on the rev pedal very slowly it will move but it wont do it in forward.
when it move in rev then the truck will drive around ok.when truck is turn off then go back to it wont drive unless you press down on the rev pedal very slowly.
  • Posted 23 May 2014 05:30
  • By greasespoon
  • joined 30 Jul'09 - 154 messages
  • somerset, United Kingdom
I too have had a similar problem, I replaced the engine speed sensor mounted between the engine and the hydraulic pump for traction.
I did not have any kind of alarm.
Regards, Mirko.
  • Posted 26 May 2014 15:38
  • By mirko_c
  • joined 16 Jan'14 - 166 messages
  • Reggio Emilia, Italy
Have you tried replacing engine speed sensor, that can cause the issues you describe. Doesnt always bring up a fault code either
  • Posted 26 May 2014 03:52
  • By Machine
  • joined 26 May'14 - 2 messages
  • no, United Kingdom
FIRST QUESTION YES
SECOND QUESTION QUICKLY
THREE QUESTION MAST OPERATE NORMALLY
  • Posted 25 May 2014 05:09
  • By greasespoon
Hello, the diesel engine accelerates if you press forward or backward?
When you release the pedal direction, the motor will decelerate slowly or quickly?
The hydraulic mast operate normally, or you have problems in this case?
  • Posted 25 May 2014 01:56
  • By mirko_c
NO CODES SHOWING
  • Posted 24 May 2014 18:24
  • By greasespoon
you dond hef code s on display??????????????
  • Posted 24 May 2014 06:44
  • By michel_v
  • noord holland, Netherlands
H25D MODEL
H2X39R00537 SERIAL
  • Posted 24 May 2014 04:10
  • By greasespoon
Type and serial number?
  • Posted 23 May 2014 21:11
  • By mirko_c
Hangcha CPYD25XW71F-JC
Flesherton, Ontario, Canada
Mitsubishi FD200
Highland, IL, United States
Orlando area, United States
Tacoma, WA, United States
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Mitsubishi FD200
Board member, UKMHA
