Engine dies when clutch released
Hi guys
I have a Hyster S7.00XL year build 1991 with a 3 speed box
Problem is the gear lever is jammed, when you select forward or reverse and release the clutch the engine dies I have jacked up the truck and the it drives although there a clunking noise briefly from what appears to be the gearbox when the clutch is released I'm pretty certain I'm going to have to remove the gearbox
Has anyone experienced this?
  • Posted 18 May 2014 08:21
  • By Forkade
  • joined 18 Jul'13 - 16 messages
  • Berkshire, United Kingdom
Hi swoop and mr fixit
Arrived site on site removed the linkage from the top of the box and found that the block had jammed between the two actuator plates under the dash,freed it off truck is running fine now, but I think it was caused by partly, a heavy handed operator And worn linkage so I have advised the customer to replace the linkage as a precaution and I have a happy customer. Many thanks again for your input.
Cheers Ade
  • Posted 23 May 2014 07:49
  • By Forkade
Hi mr fixit
Thanks for your input also I will check that out on Tuesday as well
Should not take long to whip the cover off I'm just hoping it's something simple as do not really want to take take the truck off site, once again thanks for input and I will let you what I find
  • Posted 19 May 2014 00:27
  • By Forkade
Hi swoop
Thanks for your input, I will be back on site on Tuesday so I will see what pressures I'm getting and transmission details the serial no is B024D02265M
It does not have monotrol it's a shift stick type ( old school).
Once again thanks for your input I will let you know more on Tuesday
Cheers Ade
  • Posted 19 May 2014 00:17
  • By Forkade
i'm looking in the manual for this series truck and all it shows is a powershift transmission.
can you verify this?
verify the serial number also? does it begin with C024?
if indeed this is a powershift you will have to do some pressure checking to verify what is going on in the control valve and clutch packs etc. If manual shift check the shifting linkage and make sure it is not worn or damaged as mrfixit said.
If by chance it has monotrol then there are other points to check.
If could be that it may be stuck between high/low or something like that.
first need to verify what type of transmission it is, and if it is truly manual or monotrol controlled.
  • Posted 18 May 2014 23:16
  • Modified 18 May 2014 23:27 by poster
Sounds like it stuck in 2 gears at once due to a bent or broken shift fork, (or worse)? Can you take the cover off the gearbox, that has the forks in it, and take a look?
  • Posted 18 May 2014 09:53
Airman ENCL045
Autolift E180AT36B-D5-180
Airman ENCL045
