CAT ET4000 Limit Speed
Customer wants us to limit the speed on his CAT ET4000. Can this be done through a service screen on the display or will we need to access with a laptop? I don't have any info on this model.
  • Posted 25 Apr 2014 00:22
  • By jeff_g
  • joined 13 Apr'07 - 25 messages
it can be done either way
this truck does have pre-programmed mode settings but even if they are still faster than you would like then going into the system and manually changing the output speed can be done through the dash.
There is a specific way to do it and a specific SUO parameter that needs to be changed. Without direct knowledge of navigating around in this system and having the setup instructions in hand i would not recommend attempting this adjustment on your own.
And of course with a laptop this can be done in a snap (quite faster than going through the dash)
I know you are trying to avoid calling a cat service tech but i'd recommend it.
  • Posted 28 Apr 2014 02:38
  • Modified 28 Apr 2014 02:40 by poster
Yale Lift Truck Technologies
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Bobcat appoints new UK dealer Liverpool, United Kingdom
