Lurching
Had a problem with traction control now it started lurching in fw and rev. now will not move at all,anyone have any ideas what happened?
  • Posted 22 Apr 2014 02:56
  • By rutroooo
  • joined 22 Nov'13 - 6 messages
  • Arkansas, United States
Lurching is not a good thing, I am going out on a limb and say the drive motor brushes are stuck in the holder or brushes have no spring tension due to being worn out. If it has been lurching long time then a possible commutator stone my temporarily fix or even fix the arched out bars. The unit will run with a brush missing from holder and that is where you do your dressing from. Let us know what you find.
  • Posted 25 Apr 2014 11:42
  • Modified 22 May 2014 13:21 by poster
  • By RCAV8TOR
  • Alabama, United States
It is a Nissan PO1 electric and the code is 524 TC-sensor had the same problem before and swaped the fuses on the bus bar and it ran for a while then started luching and now nothing at all,tried swapping again but did not work. Any thoughts would be greatly appreciated.
  • Posted 23 Apr 2014 00:16
  • By rutroooo
any codes?? might be throttle pot
  • Posted 22 Apr 2014 23:24
  • By Prentice
Nagano NUZ090D
Hangcha FLDCXT160
