LINDE E48P-02, SL NO- H2X337B00073, mfg year- 2011
the steering motor always running without any operations after key switch ON, Need the information that When steering motor has to start, after steering movement or brake pressing.
one more problem facing in the truck, at the time of movement of th truck if we press & depress the accelerator pedal 2 to 3 times, all the traction function will stop, then we need to switch off the truck & again switch ON,
I have wasted last three days in this problem, Your inputs will be really helpful, thanks in advance.
  • Posted 12 Apr 2014 14:49
  • By gopal_s
  • joined 29 Oct'12 - 156 messages
  • karnataka, India
GOP
Your accelerator pot neutral is probably to far from the last calibration date stored in the controller. When it happens, look in the windows2 of truck doctor for actual fault code and then address your issue from there. Also go in the calibration windows for the accelerator and look at the stored data and compare it with your actual value. If too far then calibrate it. If you cannot then replace the two pot gears that connect the pot to the pedal. If all good you might wanna look at then motor condition and the battery.
  • Posted 12 Apr 2014 22:58
  • By Dwaive
  • joined 7 Aug'09 - 33 messages
  • Quebec, Canada
Dwaive@hotmail
Montreal, Canada
what code is there on field 2 when the truck is in error??
  • Posted 12 Apr 2014 18:11
  • By michel_v
  • noord holland, Netherlands
whits foudcode ??????........ Means fault code...
There is no fault code for this problem..
  • Posted 12 Apr 2014 17:56
  • By gopal_s
  • karnataka, India
GOP
sorry contactor
  • Posted 12 Apr 2014 17:52
  • Modified 12 Apr 2014 17:53 by poster
  • By michel_v
  • Posted 12 Apr 2014 17:51
  • By michel_v
Contacts means contactor.. or what..
  • By gopal_s
  • karnataka, India
GOP
Yes we have linde computer.
  • Posted 12 Apr 2014 17:50
  • By gopal_s
  • karnataka, India
GOP
hef furst one look on conakts
  • Posted 12 Apr 2014 17:38
  • By michel_v
you hef linde computer?
  • Posted 12 Apr 2014 17:37
  • By michel_v
one more problem facing in the truck, at the time of movement of the truck if we press & depress the accelerator pedal 2 to 3 times, all the traction function will stop, then we need to switch off the truck & again switch ON,
Can u suggest What i can do, need to replace the Traction potentiometer or any other, Please sugge
  • Posted 12 Apr 2014 17:01
  • By gopal_s
  • karnataka, India
GOP
when you neet help ask
  • Posted 12 Apr 2014 16:51
  • By michel_v
Thanks Mihel.
  • Posted 12 Apr 2014 16:29
  • By gopal_s
  • karnataka, India
GOP
look ad you mail
  • Posted 12 Apr 2014 16:05
  • By michel_v
