raymondswing reach
raymond easi swing reach sa model. lift contactor slow to de-energize. continues to lift 1 second after lift request is cancelled. Does anyone know what i can check
  • Posted 11 Apr 2014 01:38
  • By DOCJOP
  • joined 8 Jul'11 - 12 messages
KEVIN L JOPSON
Thanks
Coil on valve was very tight, but checked ok. Change anyway. Then was able to learn valve. problem solved.Thanks, Again. Kevin
  • Posted 16 Apr 2014 03:36
  • By DOCJOP
there are 2 ways to do it.
you can try just centering the adjustment screw by counting the turns from end to end and putting it in the middle or just keep adjusting differently until it works as you like.
or
you can have a helper raise the platform. remove a wire from the prop valve solenoid, have your helper command lower and adjust the screw so the platform is just slowly drifting down. (you will have to re-key the truck a few times using this method it will code out 60 series codes because you have the wire off the coil.)
The prop valve is sticking up vertically out of the main hydraulic manifold in the rear left side of the truck, it is the only valve with a cap nut and jam nut you can remove. the set screw sticking up after you remove the cap nut is the adjustment screw.
if your adjustment screw does not seem to change anything the valve is faulty.
  • Posted 12 Apr 2014 07:39
  • By stam
Thanks for the reply. Adjust how?
  • Posted 12 Apr 2014 05:01
  • By DOCJOP
run weight learn. If still no good please adjust proportional lift lower valve.
  • Posted 11 Apr 2014 20:06
  • By stam
Highland, IL, United States
Orlando area, United States
Tacoma, WA, United States
Unicarriers FHGE35T5S
Taylor XC300M
New - Sale & Hire
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
