BT C4E180 error codes
Hi, somebody have the error list of this forklift?
I have errors C6, C2, 22 and B9 in display and machine have no function. I have a error list from Cesab but it not match...
Can anyone help?
  • Posted 28 Feb 2014 02:51
  • By filipe_f
  • joined 13 Jan'14 - 26 messages
  • ----, Portugal
I have face the same issue 2A is setting error for accelerator pedal selection 2 A means twin padal use for reverse and forward with out direction switch and you need to change this by using programmer if you have do let me know I will share the procedure
  • Posted 7 Aug 2022 21:52
  • By malik_y
  • joined 28 Jul'18 - 2 messages
  • United Arab Emirates
Malik Yaqub
Service Manager
Mob: 00971551662573
Hi! Can you give me some information about Cesab Blitz 315. Ihave error code 07[lift works,but i dont have traction] Thanks
  • Posted 19 Dec 2020 04:35
  • By Andrey_Mihaylov
  • joined 16 Nov'19 - 4 messages
  • Bulgaria
Hi Eric,
There should be a "Default Settings" parameter according to the manual.
  • Posted 30 Mar 2020 06:49
  • By John50
  • joined 7 Sep'19 - 153 messages
  • Netherlands
Hi John,
Thanks for the info, Its really helpful. The controller must have lost the configuration. I will buy a zapi handset and will let you know after I perform the configuration. Do you mind sharing the setpoints and parameter settings.
Stay safe.
  • Posted 30 Mar 2020 05:54
  • By Eric_Mwas
  • joined 22 Mar'20 - 3 messages
  • Kenya
2A CHOPPER NOT CONF - UNUSED
I don.t now if this will help, seems unused errorcode for this model BT
  • Posted 24 Mar 2020 07:38
  • By John50
  • Netherlands
Hi,
How about code 2A. What could be the issue.?
  • Posted 22 Mar 2020 04:33
  • By Eric_Mwas
  • Kenya
D1
TRAC_KO
DASHBOARD: The Master traction logic unit it is not readed by the dashboard
D2
MCB_TRAC_KO
DASHBOARD: The MCB control board it is not readed by the dashboard
D3
SLAVE_KO
DASHBOARD: The Slave traction logic unit it is not readed by the dashboard
D4
PUMP_KO
DASHBOARD: The lifting logic unit it is not readed by the dashboard
D5
MCB_MHY_KO
D8
ERROR_READ_PIN _CODE
DASHBOARD: The MCB control board prevents the password reading
  • Posted 10 Mar 2019 20:14
  • By FLTECH
  • joined 11 Nov'18 - 12 messages
  • Russian Federation
Hi,
22
VACC NOT OK
MASTER TRACTION LOGIC UNIT: Steering potentiometer setting not correct
6C
ANALOG INPUT
SLAVE TRACTION LOGIC UNIT: Control internal error
2C
GAIN ACQUISITION
MASTER TRACTION LOGIC UNIT: The logic unit is in data acquisition phase
B9
SET_SERIAL_ NUMBER
MCB: Automatic setting of the serial not occurred
  • Posted 10 Mar 2019 20:09
  • By FLTECH
Hi Filipe how did you solve this problem?I have some problem. Can you send me a mail? [email address removed]
  • Posted 9 Feb 2019 04:35
  • By mustafa_e
  • joined 26 Apr'18 - 1 message
  • Bornova, Turkey
I have errors D1, D2, D3,D4,D5 and D8 in display and machine have no function. I have a error list from Cesab but it not match...
Can anyone help?
  • Posted 4 Nov 2014 20:44
  • By emad_g
  • joined 3 Nov'14 - 3 messages
  • kjiyyklgyf, Egypt
Anybody knows the password to enter in parameters on display??
  • Posted 6 Mar 2014 06:59
  • By filipe_f
  • ----, Portugal
The year of forklift is 2007.
Now I have solved all the errors but have no traction, I mounted a new Main Control Board because the truck was buyed without it ( the one who stays in front under the foots on the left side ). Need I to program it? I don't have any software or cables only Zapi console to connect to the other controllers on the back of truck. I have two machines and one works, i tried the Main Control Board of other machine and have traction, with the new one no.
  • Posted 4 Mar 2014 18:47
  • By filipe_f
  • ----, Portugal
How I can see year of truck you did not write and for some older version maybe we can find solution.First tell me product year
  • Posted 3 Mar 2014 05:52
  • By nemanja_k
  • serbia, Serbia
