RAYMOND ES 102T-F45L, C14, C28, E110.
Help me please! Raymond 102T-F45L, serie 102-10-15223, error codes C14, C28, E110. I really appreciate if you send me a list of error codes. e-mail: vladykri @ yahoo.com.ar Best Regards
  • Posted 27 Feb 2014 23:55
  • Modified 1 Mar 2014 06:44 by poster
  • By vladimir_k
  • joined 28 Feb'08 - 17 messages
  • Buenos Aires, Argentina
Hey Vladimir,
On the 102t would you have a schematic of the hall sensor showing the pin out of the 4 pin plug ?.
tia
Falcon
  • Posted 9 Mar 2025 07:34
  • By Falcon_Trothrim
  • joined 9 Mar'25 - 2 messages
  • Saskatchewan, Canada
Falcon
I have the manual, send me a email to lucasdellasanta and will answer
  • Posted 11 Apr 2023 22:27
  • By DTRONICA
  • joined 11 Apr'23 - 1 message
  • Argentina
HI, ineed to lnow what's the meaning of the code error 0023 in the raymond 102T-f45L. thanks a lot
  • Posted 5 Jun 2015 06:42
  • By fernando_d
  • joined 5 Jun'15 - 1 message
  • Cundinamarca, Colombia
Ouch...C28 is the old "push the red switch to on!"
Not sure what you mean by re-set...battery re-set to 100%??
C14 is arm angle. replace both switches at base or arm. Pay attention to how they are wired.
E110 is brake fault. Most likely a broken wire to brake under the tiller. Remove 3 bolts to tiller and remove arm to inspect. Raymond must be close to Twizzler's licorice factory as their wires often twist like Licorice
Battery needs 25.3 volts to swing back to 100%
  • Posted 2 Jan 2015 14:54
  • By EasiTek
Whats the minimum voltage to the power amp to to reset for a c28
  • Posted 2 Jan 2015 09:39
  • By crown619
  • joined 28 Aug'14 - 26 messages
Hola Mike!!! Ya solucione problema con la maquina, pero tenemos 15 maquinas para hacer service completo. Por esto, estoy buscando un manual de service y despiece, si me podes mandar por favor, te agradezco!!! Si necesitas algunos manuales de otras marcas - algo hay. Saludos y gracias!!!
  • Posted 21 Jul 2014 20:27
  • By vladimir_k
e110 - braking system fault - check coil and voltage from power amp.
c14 - arm angle warning - handle could have been down on startup or microswitch/wiring problem
c28 - Master switch off - red toggle switch beside batt conn is turned to off on start up.
fyi: truck very sensitive to low battery voltage please make sure batteries are good under load before proceeding with troubleshooting.
  • Posted 18 Jul 2014 21:35
  • By stam
Todavia nesesitas la lista de los codigos??
  • Posted 18 Jul 2014 14:01
  • By mike_raymond
  • joined 18 Jul'14 - 9 messages
  • baja california, Mexico
