6BRU18 Error 35
Guys I have a 6BRU18 in Iraq, it started to show Error 35. What is that and how can I fix it? Where should I order the material to fix it from?
thanks
  • Posted 18 Feb 2014 00:50
  • By Doc_N
  • joined 18 Feb'14 - 2 messages
6BRU18
code 35 is traction throttle out of range.
check the handle. does it seem to be a bit floppy? code indicates pot voltage out of range. check the wiring on the carriage and tractor interface card. have you any previous knowledge on truck? you will have to run calibrate on unit. you will have to enter two passwords using the hour meter select button, power control select button and the up down buttons.
  • Posted 19 Feb 2014 14:52
  • By fixnproblems
  • joined 19 Jan'13 - 66 messages
No replies? :'(
  • Posted 19 Feb 2014 07:20
  • By Doc_N
Bobcat appoints new UK dealer Liverpool, United Kingdom
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Orlando area, United States
Dallas, TX or Lexington, KY, United States
Highland, IL, United States
Tacoma, WA, United States
Board member, UKMHA
